Old 12-23-2005, 12:12 AM   #1
kikwear002
kikwear002 is on a distinguished road
Default timing help
how do you do the timing on a 87 turbo? i dont see how to point the cps right., i read the manual but how do you get the gear on the right tooth?
kikwear002 is offline   Reply With Quote
Old 12-23-2005, 12:43 AM   #2
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
I'm in the same boat. You need to make sure the engine is at TDC 0 degrees. You do this by rotating the crank so that the timing marks on the cam gears line up with their perspective marks, as well as zeroing the crank pulley on its mark. You then need to open the cover on the CPS and align the trigger so that it's slightly before where it lines up on the trigger because when you put the CPS in, it will rotate clockwise as the gears mesh. Keep trying so that when you put the CPS in, the trigger is aligned. Make sure you do this with plenty of play to adjust the CPS like a distributor.
Then refer to this page to set it:
http://www.cygnusx1.net/supra/techti...ng_timing.html
Bullz_EyE is offline   Reply With Quote
Old 12-23-2005, 06:24 AM   #3
kikwear002
Its Alive!!!!!!!!!!!!!!!!!
Old 12-23-2005, 04:25 PM   #4
Bullz_EyE
Bullz_EyE's Avatar
Glad I could help.
Old 12-24-2005, 05:06 AM   #5
kikwear002
Originally Posted by Bullz_EyE
Glad I could help.
you didnt help. the coils had corrision on them. but thanks
Old 12-24-2005, 09:45 AM   #6
Bullz_EyE
Bullz_EyE's Avatar
Doh..............
Old 12-24-2005, 05:18 PM   #7
dcrusupra
dcrusupra's Avatar
Harsh. lol
New Rebuild
My CarDomain
Old 12-25-2005, 01:40 AM   #8
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
I know you are set already, but just to mention, there is also another way in addition to the way the TSRM states.
JBLMK3 did a write up with pics:
http://www.jblmk3.com/id92.htm
(Some find it easier that way [me].)
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
advanced timing? sd88supra MKIII Supra 7 04-27-2008 03:44 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
timing issues stuck1 MKIII Supra 0 03-27-2006 02:16 PM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
