Old 12-25-2005, 08:10 PM   #1
frankwhite
frankwhite is on a distinguished road
Default what kind of clutch do you recommend?
I need a new clutch in my 89 turbo...any suggestions on what i should get? is there really that big of a difference between a stock toyota clutch and an aftermarket one? I was thinking a stage 1 exedy or spec...heard these are good. Lemme know. Thanks
frankwhite is offline   Reply With Quote
Old 12-25-2005, 08:16 PM   #2
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
Exedy, ACT, Clutch Masters are all pretty good clutches. It depends on your budget and application. If you've got regular bolt-ons and you're not going to take your car much further, stick with a stage 1 or 2. Don't get a stock one, you might as well upgrade if you've got to replace it.
Bullz_EyE is offline   Reply With Quote
Old 12-26-2005, 11:12 PM   #3
frankwhite
Im looking to spend around 300 give or take some, for the clutch kit. I was wondering how much i can expect to spend on labor since i dont know how to install it myself. How long should it take a certified mechanic to put my clutch in? I just dont wanna get ripped off. Thanks.
Old 12-27-2005, 07:04 PM   #4
skunk
skunk's Avatar
skunk is on a distinguished road
I think if you are going to up the power you need one of these....this is my next step
http://935motorsports.com/catalog/in...Path=79_14_148
skunk is offline   Reply With Quote
Old 12-28-2005, 09:36 AM   #5
frankwhite
Default which one
Any suggestions on which one from the 935 motorsports page. Im lookin the spend 300-400 on kit.
Old 12-28-2005, 10:04 AM   #6
joel w
joel w's Avatar
Mine was slipping in 3rd 4th and 5th gears due to mods, so i went with a ebay XTD stage 3 pressure plate and disk but i had chatter and grabbing problems. so i took it apart and used a stock disk instead of the 6 puk and kept the stahe 3 pressure plate. I like it, its smooth like butta and no slipage under loads..
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
Clutch Troubleshooting ivire MKIII Supra 9 11-09-2006 01:29 AM
