Old 12-29-2005, 05:27 PM   #1
lilsmitty
lilsmitty is on a distinguished road
Default Engine still wont start 87 supra 7mge
OK i put a new engine in my car. Its all in i got the last parts last night n was up all night trin to get it to start but it fires for like 2 seconds and shuts off... just wont stay running any ideas? i tried almost everything witht the timming
lilsmitty is offline   Reply With Quote
Old 12-29-2005, 07:29 PM   #2
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
Engines need 3 things to start. Compression, fuel, and spark. Time to start process of elimination. If you have all 3 your timing may be off or something may be wrong with a sensor or the ECU.
Bullz_EyE is offline   Reply With Quote
Old 01-01-2006, 05:08 PM   #3
88Supraboy
88Supraboy's Avatar
88Supraboy is on a distinguished road
check the Mass Air Flow sensor, if its not working right the car will start then die right away because its wating for a signal from the sensor. I had mine off once and it was doing it, i didnt understand why it would die but thats the whole reason for the sensor.
Good Luck
88Supraboy is offline   Reply With Quote
Old 01-01-2006, 08:46 PM   #4
mattsmall
mattsmall is on a distinguished road
iv got an extra ecu for a 7mge with a manual trans 15 and ill ship it out to you.
mattsmall is offline   Reply With Quote
Old 01-01-2006, 10:13 PM   #5
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
Have you checked for any codes?
If you have not, this may be of help:
http://www.cygnusx1.net/supra/techti...rrorcodes.html
If you have, did you get any codes?
TONY! is offline   Reply With Quote
Old 01-02-2006, 01:40 AM   #6
rnoswal
rnoswal's Avatar
Did it run with the old engine? It does sound like the airflow meter. The cold start injector is getting it started but then no signal to the rest of the injectors to keep it going. Try to make sure there are no big air leaks anywhere.
Russ
Old 01-02-2006, 08:58 AM   #7
kikwear002
kikwear002 is on a distinguished road
the coils, check them for corrorision! happened to me couldnt figure it out. I cleaned them up and she ran perfect!
kikwear002 is offline   Reply With Quote
Old 01-03-2006, 03:11 AM   #8
lilsmitty
mass air flow senser is makin a funny noise like a little tin clunk every once in a while....
Old 01-03-2006, 10:42 AM   #9
lethalwithasupra
lethalwithasupra is on a distinguished road
fuel ? supras switch the fuel pump on with the starter, maybe it isnt keeping on. it'd run untill the rail ran out of juice
So I bought this old Honda bike, an NSR250. Bit of a street racer, I guess. I'm told they're fast.
Delivering it home with a friend driving the Supra for the first time. I drop gears and make a scream from the twin pipes flowing down this pony's flanks and it takes off like it's tail's on fire.
I look back when the Honda gets to its tap-out and the Supra's only two lengths behind. No one I've let ride my bike has told me its slow, they've all loved the thing. That car is a good thing indeed.
lethalwithasupra is offline   Reply With Quote
Old 01-12-2006, 12:16 AM   #10
lilsmitty
what would cause the injectors not to work at all?
Help!!! Cannot start Supra jagman MKIII Supra 3 12-07-2007 08:41 PM
Best year and engine Supra to buy, your thoughts please. Jpw MKIV Supra 2 11-17-2007 07:58 AM
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
