Old 12-30-2005, 11:08 PM   #1
White targa
White targa's Avatar
White targa is on a distinguished road
Unhappy Stalling 88 turbo
My battery died yesterday and upon test drive she stalls every time i push clutch in while driving. I have a new bov venting to atmosphere should i make it blow into intake for ecu to relearn car? n e help appreciated thnx in advance
White targa is offline   Reply With Quote
Old 12-31-2005, 01:42 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
what sort of bov is it?
is it adjustable?
easy to fix ur problem... undo what you last did to the car and see if it changes.. if it does... that's ur problem
but yea i'd say ur bov is whats causing it
Pics of my build.
Do a diagnostic first!
Old 12-31-2005, 02:17 PM   #3
Isphius
Isphius's Avatar
I had this same problem. it was because my idle adjustment screw was loose. get a nut from home depot and put it on there and tighten it down when you have it adjusted
my car did the sames thing. would stall everytime i pushed the clutch in. then it would start and run perfectly fine.
Old 01-01-2006, 12:47 AM   #4
White targa
acctually i drove the car the problem seemed to have sort itself out (30 plus miles) idle was low like 500 after long drive idle rose to 750 and car dorve like beautiful again car ran fine before battery died must be ecu just relearning car in general thnx for ideas
