Old 01-02-2006, 06:25 AM   #1
adamh88
adamh88 is on a distinguished road
Question Timing belt rubbing against lower front cover
I have a 7mgte and it just started making a slight noise from the engine so i took off the timing cover and the belt is starting to rub on the lower metal part of the cover just wondering if this has happend to anybody else or if anybody has any ideas?????
adamh88 is offline   Reply With Quote
Old 01-02-2006, 06:31 AM   #2
joel w
joel w's Avatar
my lower timing gear had the retaining flange snap off and that then let the belt slip forward and start to shred on the cover....
Old 01-05-2006, 07:56 PM   #3
adamh88
Thanx, Where you able to fix it yourself or did you just take it to a shop? i had one shop quote me at $380.00 was wondering if that sounded reasonable or not.
Old 01-05-2006, 08:34 PM   #4
Smile Reasonable ??
Here at my shop it would cost $50 for the belt (Gates brand), $260 labor, and if the tensioner bearing was bad, about $40. Our rate is $65 hr.
If you've done a water pump, or sparkplug change, you can handle the timing belt job.
Old 01-05-2006, 11:08 PM   #5
joel w
joel w's Avatar
yes, i did it myself, getting the crankbolt loose was the hard part. (starter bump trick) and i had to buy a new lower timing pulley from the dealer.
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Timing belt is escaping! go.stfu MKIII Supra 7 07-14-2007 10:38 PM
Water in Oil???? HG??? Z'mnypit MKIII Supra 27 05-03-2007 12:40 AM
Noise Inside Lower Timing Cover mrnickleye MKIII Supra 10 04-26-2007 05:14 AM
How can I remove Front Spoiler/Bumper Cover 85-86? droptopsupra MKII Supra 4 04-27-2006 12:26 PM
