I have a quick question on rod knocks. I did some reading about this, and I have only found cases where people had this problem with low oil levels. Is it possible to get a rod knock with the oil levels being fine??
I just checked my oil yesterday, and its fine. And tonight when I got home, I noticed my engine was idling kind of noisy. I looked under the hood, and I'm scared to say it, but sounds like a knock. But yet my oil level is ok, unless it is possible to develop a knock with normal levels. And if so, how does it happen? |
Sounds like you've done some research and I concur. I can't speak from experience, but from what I've gathered it occurs usually when oil levels drop low. So, in your case, I don't know what it could be.
one time my main pully was loose . you couldn't tell it was loose by looking but you could tell by twisting it a little , damn if that didn't sound like an engine knock
it could be that the previous owner had run it low on oil and it was just a matter of time
are you able to take any video of it?
I too have seen a loose crank pulley sound like a rod knock, on a couple of cars.
Rod knock develops due to the bearing(s) on the rod that attach it to the crankshaft, getting too much clearance (gap, play). It can happen when the oil LEVEL gets too low, and you go around a corner and the pump doesn't pick up oil for a moment. Lack of oil at the bearing is the cause. Oil quality plays a role. If the oil level NEVER got low, but has not been changed for too long, it won't lubricate very well. Repeated high RPMs stress the bearings. I change my oil every 2k, just to be safe. Oil is still cheap enough, and cheaper than engine work.
#6 |
Yea, I always keep an eye on my oil and get it changed a lot. I'm scheduled for a tune up as well. I never let the oil get low, I'm always paranoid about it. I always have bottles of oil on hand in case I need to top up.
I will check my crank pulley and see if it is loose. This morning when I started up my car, it was still there, I drove it to work and came out 5hrs later, and I couldn't really hear it. Odd... As for the previous owner, it was my uncle, and he babied this thing. So I think that rules out lack of care on his part haha. |
#7 | |
![]() Quote:
Picture Of Knock Sensor Locations | ravenmaster | MKIII Supra | 10 | 01-31-2012 03:37 PM |
Starting isssues and spark knock Q's | spudz29212MKIII | MKIII Supra | 65 | 05-30-2008 06:44 PM |
Engine knock @ 1700-2300 | rstutler | MKIII Supra | 8 | 03-07-2008 07:36 PM |
Rod knock?? | wetwilly | MKIII Supra | 8 | 02-25-2006 04:00 PM |
Knock sensor..........ebay. | rnoswal | MKIII Supra | 0 | 11-06-2005 07:24 PM |
