Old 01-07-2006, 03:43 AM   #1
kikwear002
kikwear002 is on a distinguished road
im thinking your cooling problem is the fan clutch, is the fan real easy to turn when the car is hot?
kikwear002 is offline   Reply With Quote
Old 01-07-2006, 09:19 AM   #2
stumpjumper
stumpjumper is on a distinguished road
Check your TPS for the unstable idle speed. Happened in my pickup and it solved the problem.
Maybe get your radiator pressure tested and cleaned. YOu aren't having to give it coolant periodically are you?
As long as it's not overheating at speed I'd say it's safe to drive.
stumpjumper is offline   Reply With Quote
Old 01-07-2006, 07:14 PM   #3
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
You know for the teeth of the timing belt, I thought there was only one belt for the 7M motor/s...?
On my 7M-GTE motor, I have a 159 tooth timing belt.
If someone can confirm they are the same as the N/A models, then it would be 159.
I would be interested in knowing if N/A's have different belts than Turbos.
Edit: I would be very cautious of a heating problem. Overheating can crack blocks (seen it happen on a 7M) and can warp the head too.
If you are on a road and you have a temp spike, it may be so fast and you may not even notice, while the needle could be beyond where the gauge reads or intended to even measure.
TONY! is offline   Reply With Quote
Old 01-08-2006, 04:22 AM   #4
mrnickleye
mrnickleye's Avatar
Thumbs up No water, no gauge reading
This reminds me to let you know. BEWARE !!!
The temp sending unit is located on the thermostat housing. It is one of the highest points on the engine with coolant. If your coolant level drops below the sender, your gauge will not raise up, because it needs coolant touching it to send an accurate signal to the gauge.
Your gauge will usually drop down a bit, and make you think your engine is actually running cooler.
So learn your car, and know where your gauge normally operates at. Look at it often when you drive.
And make sure your radiator cap holds 13lbs, they do get weak as the years go by. ( I almost lost a freshly rebuilt motor in my '65 Mustang due to a cap that was supposed to be 14lbs, but only held 7lbs).
All of the above happened to the Mustang.
Want to buy a Supra, though having some problems finding one. Cypherbku MKIV Supra 3 03-03-2009 01:45 AM
problems problems problems.... 86SupraMan MKIII Supra 5 02-04-2008 04:28 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Oil leak problems adellicson MKIII Supra 1 03-04-2007 10:11 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
