-   -   blocked off EGR (http://www.toyota-supra.info/forums/mkiii-supra/2998-blocked-off-egr.html)
88Supraboy 01-08-2006 02:40 AM
blocked off EGR
Ive seen some block off plates for our Supras EGR valve. i thought it was needed? can someone tell me the advantiges of this. but it does make sence because why would you want exhaust gas back in your engine?!
mrnickleye 01-08-2006 03:18 AM
I simply did a search on this forum and came up with this thread. Hope it helps. Also try searching for just egr removal, etc. There may be more threads.
http://www.toyota-supra.info/forums/...t=block+plates
Removal will not get you more HPs. but a cleaner engine bay.
Bullz_EyE 01-08-2006 07:06 AM
I was about to do it, I even ordered the block off plates, but cancelled my order after someone reminded me I live in CA (although I do have hook-ups), I want my car to be legitimately street legal. You won't need a block-off plate for the back of the head, as these two plates are all that's needed to effectively delete your EGR.
http://www.suprasport.com/product.as...d=231&catid=45
http://www.suprasport.com/assets/ima...Picture007.jpg
88Supraboy 01-08-2006 03:12 PM
all i needed, thanks
EVAN CORNELIUS 02-24-2006 05:04 PM
Mississippi Boy
Let Me Know How The Block Off Plates Work I Just Ordered Mine. Thanks
Levi1717 05-08-2006 01:25 AM
when you block off the egr what does it do? If someone could explain the whole thing it would help. thanx
mrnickleye 05-08-2006 02:53 AM
here is egr explained
http://www.fordscorpio.co.uk/egr.htm
flight doc89 05-08-2006 11:27 PM
I read somewhere that while the egr helps emissions, it also lowers the temp of the last two cylinders (because they get shafted by the cooling system in a straight-6), and the egr valve closes at WOT anyways. (i just read this somewhere, so i can't guarantee accuracy)
