Old 01-12-2006, 03:49 AM   #11
j3pz
oh ya two more points for jesse! *pats self on back* now if only i am that lucky with the lottery!
Old 03-30-2006, 05:06 PM   #12
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Long time ago I had a Buick-powered Ford. Replaced a leaking water pump with a rebuilt one, and it didn't pump water, period. I just couldn't believe it at first, but even with the t'stat OUT it wouldn't pump water.
Pulled the pump and found that some goon had replaced the impeller with a new one. Problem was the hole for the shaft was a bit oversize--just tight enough to hold it on when inverted.
Just my luck to get THAT one from the auto store----.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 04-09-2006, 09:05 AM   #13
Isphius
Isphius's Avatar
Last Night my car got a little on the hot side going down the highway. not really over but a little highre than normal ,which is like half way up. I pulled up to my friends and i let it cool down. I was going to check the radiator....and it was cold. so I opened it....water explosion. It wasnt even hot. like there was steam trapped in there somewhere with nowhere to go. The water that ended up on my face luckily wasnt hot, but it was steaming afterward. So i put some water in it and drove home, felt like it had a dead cylinder or 2. No power. I got up to about 35 top speed. Does anyone know what happened? im kinda thinking there is water in the cylinder. And the temp gauge was normal but it was steaming from the cylinder head under the TB when i got home home. ahhh help me please!
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
Transmission Issues xpurplepandasx MKII Supra 6 08-23-2007 02:12 AM
Boost Issues abhattan MKIII Supra 1 04-25-2007 02:57 AM
Heating problem Lee MKIII Supra 3 10-04-2005 11:50 AM
