Old 01-06-2006, 08:24 AM   #1
kewlcoconut
kewlcoconut is on a distinguished road
Default Rod Knock
I have a quick question on rod knocks. I did some reading about this, and I have only found cases where people had this problem with low oil levels. Is it possible to get a rod knock with the oil levels being fine??
I just checked my oil yesterday, and its fine. And tonight when I got home, I noticed my engine was idling kind of noisy. I looked under the hood, and I'm scared to say it, but sounds like a knock. But yet my oil level is ok, unless it is possible to develop a knock with normal levels. And if so, how does it happen?
kewlcoconut is offline   Reply With Quote
Old 01-06-2006, 08:37 AM   #2
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
Sounds like you've done some research and I concur. I can't speak from experience, but from what I've gathered it occurs usually when oil levels drop low. So, in your case, I don't know what it could be. Just run it and keep checking the oil. If worse comes to worse (knock on wood), you really don't have choice but to do something about it, as there is really nothing to prevent it. Best of luck, hopefully there's more input.
Bullz_EyE is offline   Reply With Quote
Old 01-06-2006, 12:03 PM   #3
ddmcse
ddmcse's Avatar
Cool
one time my main pully was loose . you couldn't tell it was loose by looking but you could tell by twisting it a little , damn if that didn't sound like an engine knock
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 01-06-2006, 09:34 PM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
it could be that the previous owner had run it low on oil and it was just a matter of time
are you able to take any video of it?
Pics of my build.
Do a diagnostic first!
Old 01-07-2006, 01:31 AM   #5
mrnickleye
mrnickleye's Avatar
I too have seen a loose crank pulley sound like a rod knock, on a couple of cars.
Rod knock develops due to the bearing(s) on the rod that attach it to the crankshaft, getting too much clearance (gap, play).
It can happen when the oil LEVEL gets too low, and you go around a corner and the pump doesn't pick up oil for a moment. Lack of oil at the bearing is the cause.
Oil quality plays a role. If the oil level NEVER got low, but has not been changed for too long, it won't lubricate very well.
Repeated high RPMs stress the bearings.
I change my oil every 2k, just to be safe. Oil is still cheap enough, and cheaper than engine work.
Old 01-07-2006, 02:22 AM   #6
kewlcoconut
Yea, I always keep an eye on my oil and get it changed a lot. I'm scheduled for a tune up as well. I never let the oil get low, I'm always paranoid about it. I always have bottles of oil on hand in case I need to top up.
I will check my crank pulley and see if it is loose. This morning when I started up my car, it was still there, I drove it to work and came out 5hrs later, and I couldn't really hear it. Odd...
As for the previous owner, it was my uncle, and he babied this thing. So I think that rules out lack of care on his part haha.
Old 01-07-2006, 05:45 AM   #7
Bullz_EyE
Bullz_EyE's Avatar
WoWzerz! Drive your car much? Just a note (not to you, just being general), the recommended interval for oil changes is every 3000 miles or 3 months, which ever comes 1st. It's been studied before that changing every 3000 may be a bit excessive, although I religiously change it at that interval.
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
Rod knock?? wetwilly MKIII Supra 8 02-25-2006 04:00 PM
Knock sensor..........ebay. rnoswal MKIII Supra 0 11-06-2005 07:24 PM
