Old 01-16-2006, 05:54 PM   #1
87supraturbo19
87supraturbo19 is on a distinguished road
Post no spark
hey guys, i have an 87 turbo. I have spark on one cylinder every once in awhile, only a soon as you crank, like one spark. But none on the others. i put a used ignitor on. i ohmd out my cam position sensor and checked my air gap and it checks good. i ohmd my coil pack, its supposed to check .3 to .5, it checks .8. and it has a small crack in it. I have 12v power to my ignitor and coil pack. If that sounds like a good choice i would appreicate a conformation and/or any info. thanks
i would also like to know all of the grounds the would affect this too. thanks again
87supraturbo19 is offline   Reply With Quote
Old 01-17-2006, 07:45 AM   #2
lethalwithasupra
lethalwithasupra is on a distinguished road
bridge out the Te1 and E1 ( someonell correct me on those terminals ) and see if it brings up a fault code
So I bought this old Honda bike, an NSR250. Bit of a street racer, I guess. I'm told they're fast.
Delivering it home with a friend driving the Supra for the first time. I drop gears and make a scream from the twin pipes flowing down this pony's flanks and it takes off like it's tail's on fire.
I look back when the Honda gets to its tap-out and the Supra's only two lengths behind. No one I've let ride my bike has told me its slow, they've all loved the thing. That car is a good thing indeed.
lethalwithasupra is offline   Reply With Quote
Old 01-17-2006, 08:18 AM   #3
87supraturbo19
Does the check engine light have had to be on to pull a code? Is it really going to tell me something i dont already know. I mean I already got it pretty narrowed down. thanks for the info.
Old 01-17-2006, 08:44 PM   #4
87supraturbo19
Can anyone tell me which wires plug in were on my themostat housing. I think there are two plugs. My wires got pulled from the connectors and the connectors got lost so I dont know which colors go to which plug.
Old 01-22-2006, 04:48 PM   #5
87supraturbo19
I tryed to pull codes and had no luck. Does anybody know of a relay that might keep me from getting any spark. its either that or my cps. i have checked everything i know.
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
