#1 |
Hey guys. Just wondering, I have an 89 turbo and i was told that i have to change the oil in a special way because i am dealing with a turbo now instead of an N/A engine. is this true? Or can i just change the oil in the car like any normal car. Second, standard gasoline is ok to use right?
#2 |
Change the oil every 3,000 miles or every 3 months, whichever comes 1st.
Your boosted Supra requires 91+ Octane.
Function Over Form - Form Follows Function 88 MkIII Jurbo |
#3 |
Hey thanks. I appreciate the help....
#4 | |
![]() Quote:
That helps us prime the filter. Priming the filter means to put oil in it then then screw it on so that there is oil upon start up. I would do that for any car if I could. Some other like to take it a step further and have the engine turn over before it starts. Some ways to do that would be to remove an ignition wire or the EFI fuse, but I don't go that far.
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____ /. . . \ . . . \ . .\ ( ]/ . . . . \ . . . \ . .\[ ) _________________ /OO]====(W)====[OO\ [___________________] [ [O] ///______\\\ [O]_] ____________________[||]______________[||]____________________ |
Just got my first supra noob questions help is appreciated | vivalajon96 | Non-Generation Specific Questions | 0 | 03-29-2008 01:40 AM |
Techincall questions.. im a supra NOOb | Boostesi | MKIII Supra | 17 | 08-17-2007 03:53 AM |
noob questions on 89 supra | kidthunder650 | MKIII Supra | 4 | 03-03-2007 02:35 AM |
noob questions | peter88 | Non-Generation Specific Questions | 1 | 11-01-2006 01:36 PM |
Need your gus help- a few questions | ravenmaster | MKIII Supra | 10 | 10-21-2006 09:59 PM |
