Old 01-19-2006, 03:55 PM   #1
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
Default Vacuum Help (Again)...
Where does this hook up?
Function Over Form - Form Follows Function
88 MkIII Jurbo
Bullz_EyE is offline   Reply With Quote
Old 01-20-2006, 01:24 AM   #2
mrnickleye
mrnickleye's Avatar
That goes to the 3" intake tube that comes off the AFM and leads on up to the throttle body. It provides a 'filtered' air intake source, so dirt does not enter the engine.
Old 01-20-2006, 01:52 AM   #3
joel w
joel w's Avatar
agreed, bottom fitting on the accordian hose.
Old 01-20-2006, 03:19 AM   #4
Bullz_EyE
Bullz_EyE's Avatar
Thanx , I should've poked around a little because I found it without checking back to the thread. I always like to be cautious though.
88 MkIII Jurbo
Old 01-20-2006, 04:20 AM   #5
mrnickleye
mrnickleye's Avatar
Smile
I had my intake tubing off several times over the past couple of years, and I sometimes forgot to put that vacuun hose back on. I would remember soon after while driving, and have to pull over to plug it in. Its easy to forget when its black, like most of the stuff under the hood.
Those colored vacuum lines are the way to go.
Vacuum hose suprabahamut MKIII Supra 10 01-08-2009 12:52 AM
Vacuum??? fienloco MKIII Supra 4 08-21-2008 04:36 AM
really could use help - vacuum, race on the 26th carl johansson MKIII Supra 2 12-24-2007 11:37 PM
Newbee: Question About Vacuum lines.. Alejo_NIN MKIII Supra 3 01-12-2006 07:18 AM
vacuum advance/retard tonster MKII Supra 0 09-16-2005 06:43 PM
