Old 01-23-2006, 10:40 PM   #1
XKeyLocX
XKeyLocX's Avatar
XKeyLocX is on a distinguished road
Default Quick Question!
Hey i was wondering wat the diffrence was between the wastegate and the blow off valve ... ? ... and i was also wondering since i have a turbo if i should go with the 3" catback exhaust .. i dont want it to loud though ! ... thanks ryan
XKeyLocX is offline   Reply With Quote
Old 01-23-2006, 11:21 PM   #2
joel w
joel w's Avatar
the waistgate is a swing valve inside the turbo that is held shut untill boost is achived. then it opens as needed to let the extra exhaust gasses bypass the turbo to maintain the set psi.. The bov vents the pressure inside the intake manifold when you let off the gas or shift,
research the exhaust, a cat back system probably wont be to loud.. for better performance, id get a downpipe, but thats just me..
Old 01-24-2006, 12:37 AM   #3
KNYFE
KNYFE's Avatar
KNYFE is on a distinguished road
The sound from your exhaust is based FAR more on the muffler you use then the size of pipe. If you use a ricer little coffee can it will be loud and buzzy but if you buy a good full size muffler you will love the sound.
http://www.cardomain.com/id/FastnLowI30
Supra, I30 and A8 are above...
KNYFE is offline   Reply With Quote
Old 01-24-2006, 01:49 PM   #4
XKeyLocX
XKeyLocX's Avatar
alright thanks guys ... appreciated
Front Strut Bar - Quick Question Grandavi MKIII Supra 6 09-25-2008 06:03 PM
Quick question 88ProjectSupra MKIII Supra 1 04-24-2008 11:56 PM
quick question need answered quickly switchblade Non-Generation Specific Questions 5 07-21-2007 12:47 AM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
