Old 01-26-2006, 10:04 PM   #1
87supraguy
87supraguy is on a distinguished road
Default differential
I have an 87 na with a locking rear differential my question is, is the non turbo lock diff. the same as the turbo diff? i have to replace my diff anyways but i also plan on doing the turbo swap so want to make sure i get the turbo rear end. also was wondering i found a steel one piece drive shaft that weighs half as much as the two piece stock drive shaft it's $300 hundred buck aliminum i think was $450 and weighed a 1/4 less than stock would one of these be worth the price? can i get one cheaper newhere else?? one last question while im at it. i heard that if you do the swap your factory tach doesnt work is this true?? if so is there a way to wire it so it does work? Plan on doing some work in the next month or so so when the snow is all gone i can get cindy (my car) back on the road im excited and cant wait!!! Thanks
87supraguy is offline   Reply With Quote
Old 01-27-2006, 01:49 AM   #2
The LSD diffs are built the same, but the gear ratios are different n/a to turbo, n/a being higher.
For me, $300 is alot to gain a little off the weight. Put $$$ else where is what I do first. intake, exhaust, tires/wheels, stereo, etc.
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
MKIII Differential SupraSleuth Non-Generation Specific Questions 3 08-06-2008 02:44 AM
Rear differential question finaltable MKIII Supra 9 11-13-2007 07:49 PM
limite slip differential suprabahamut MKIII Supra 0 08-22-2007 04:08 AM
Differential gearing changes? jibbby MKIV Supra 0 02-23-2006 07:51 PM
