Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 06-16-2007, 10:34 PM   #61
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
My block is cracked I posted some pics under the thread "Cracked Block"
carfanatic89 is offline   Reply With Quote
Old 11-11-2007, 09:13 PM   #62
supramacist
supramacist's Avatar
ebay is your first fluck up.
www.horsepowerfreaks.com
EXT. 103
Speak to dave.
Old 11-25-2007, 11:41 PM   #63
toyota4life198031
toyota4life198031 is on a distinguished road
Default coolant light keeps coming on
ok so i was told my head gasket might be on the way out the only thing is it was just done 50 000 kms ago right before i bought it by the toyota dealership
the problem im having is im losing coolant but i dont know from where because i dont have a puddle under my car i had a hose that was leaking but that was tightend up and my water pumb might be leaking but not enough to keep bringing my resivor light on ...i work in a shop so i have had the mechanic look at it but its hard to say what it is anyone have any ideas?
and first time posting so i have no idea if i just replied to a msg by accident lol
toyota4life198031 is offline   Reply With Quote
Old 01-06-2008, 04:57 AM   #64
Starlight1988
Starlight1988's Avatar
Starlight1988 is on a distinguished road
I'm having a similar problem with my car. but i found my problem and it was a leak and just need to replace a busted tube for the radiator
zoom zoom!
Starlight1988 is offline   Reply With Quote
Old 02-23-2008, 06:05 PM   #65
Oropher
Oropher's Avatar
Oropher is on a distinguished road
I just got done replacing my BHG. My temperature guage liked to spike a lot unless I kept the engine going at above 3000 RPM. We had done everything else, new water pump, new radiator, new fan configuration...nope. Dug into it and found the BHG and erosion on the head. Had to get the head planed, 10/1000 (which is not reccomended by Toyota) and put the thing back together. So far it has stopped the overheating and has stopped blowing the coolant out of the system, but now I have an injector (or something) leaking fuel and can't find where to plug the knock sensor back in so, hopefully I'll get that soon.
Oropher is offline   Reply With Quote
Old 03-12-2008, 06:06 AM   #66
88supra_dude
88supra_dude is on a distinguished road
Originally Posted by Dejvid1785 View Post
I have a 88 NA supra, i'm trying to figure out if my thermostat is out or is my head gasket blown? What usually happens or what symptoms there are when your head gasket is blown?
my supra did tat on me too. i thought it was the thermostat, switched tat, but still, it kept saying it over heats. then, after like 3 month, it wouldnt start anymore. took it to the shop and they diagnosed it wit a BHG and need all my cylinders replaced.
vroommm, vrooooommmmmmm -pshhhhhh-
88supra_dude is offline   Reply With Quote
Old 04-25-2008, 08:48 PM   #67
toyota4life198031
Default damn tools
does anyone know where i can get the special tool to torque the nuts back onto the head
Old 03-21-2009, 11:09 PM   #68
mkIII supra turbo gav
mkIII supra turbo gav's Avatar
mkIII supra turbo gav is on a distinguished road
all mine does is heats up no oil water mix none out the back too
mkIII supra turbo gav is offline   Reply With Quote
Old 05-24-2009, 03:15 AM   #69
evosupra
Banned
Default For you guys using an Autozone gasket !
DONT !
do not put a cheap $50 head gasket from felpro,,,
Get yourself a Titan or HKS, or cometic metal 2.0 mm gasket.
Pretty much guaranteed not to blow !
Old 07-21-2009, 02:11 AM   #70
vin6921
vin6921 is on a distinguished road
Default overheating, and blowing coolant out the exhaust
Hi , Im planning on buying an 87 non turbo supra and the guy that wants to sell it says that its overheating, and blowing coolant out the exhaust could this be because of a bad head and gasket , i need help figuring it out
vin6921 is offline   Reply With Quote
HTML code is On
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Blown head gasket? h8z2luze MKIII Supra 30 06-03-2006 03:18 AM
