#1 |
hey everyone, id like to put a 2jz fuel pump on my 1jz. Is that a direct bolt-on upgrade or are there any modifications/alterations required?
#2 |
Techinically, if it's just the pump, it should drop right in, considering it's just a electric motor anyway, the car won't notice the difference, tho your motor will
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors. Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome. |
#3 |
i believe their will be a differenece because the 2jz fuel pump supplies enough gas to maintain the motors speed and the Twins turbos which means it would be bigger than your stock 1jz one, only problem that might take place is that it might jst flood your engine because your car wouldnt be burning the gas quick enough.
Tags |
1jz, 2jz, fuel, fuel pump |
no power to fuel pump | carcrzy920 | Non-Generation Specific Questions | 0 | 06-05-2009 05:51 PM |
fuel pump mounting bracket | GremlinMKIII | MKIII Supra | 4 | 09-06-2007 07:08 AM |
MSD fuel pump? | redmaro | MKIII Supra | 6 | 08-24-2007 04:09 PM |
Testing for bad ECU, &/or bad Fuel Pump | elliotl | MKIII Supra | 0 | 08-21-2007 10:42 PM |
Fuel pump hanger for 87 supra non turbo | rlipp69 | Non-Generation Specific Questions | 0 | 06-16-2007 03:23 PM |
