Old 01-29-2006, 02:31 PM   #1
ekoston69
ekoston69 is on a distinguished road
Default Fuel cut 1g-gte
Has anyone found a way around fuel cut on a 1g-gte without using a fcd? Does a safc eliminate fuel cut?
ekoston69 is offline   Reply With Quote
Old 01-29-2006, 11:24 PM   #2
stikasupra1ggte
stikasupra1ggte is on a distinguished road
Default i found a way.... not the best... but works
all i did was take out the speedo cable at back of dial.....
therefore i have no speed reading but i know how fast im going with what revs and what gear....
so not cut off valve...... no speed limited...
no dinger at 110......
stikasupra1ggte is offline   Reply With Quote
Old 02-01-2006, 02:40 AM   #3
ekoston69
Haha nice. Sorry i actually meant the boost fuel cut not the speed limiter should have specified. Thanks for the reply though ill keep that one in mind I do like my speedo though..
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
