Old 01-30-2006, 06:33 AM   #1
aznwaterboy
aznwaterboy is on a distinguished road
Default automatic to manual conversion
anyone know what i would need to convert a 1jz from auto to manual? i know i need the r154 transmission, but what else would i need? i think i need the ecu from a 5spd 1jz, the reason i'm asking is cuz its a lot cheaper to buy an auto 1jz instead of a 5spd 1jz
aznwaterboy is offline   Reply With Quote
Old 10-04-2006, 02:29 AM   #2
tone loc
tone loc's Avatar
you need
bellhousing
driveshaft
brake pedal
cluch pedal assembly
clucth
flywheel
trans mount
trans-engine braces
all the misc. clucth parts like throw out bearing thrust cone
master cylinder
slavecylinder
clucth lines
new cluster
shifter cover and other related parts
and then you need to get all the small stuff like bolts
Automatic to Manual Conversion sprite059 MKIII FAQ 30 09-02-2010 12:47 AM
Automatic To Manual InColdBlood MKIV Supra 6 03-19-2007 07:52 PM
loc's automatic to manual conversion!!!! tone loc MKIII Supra 14 09-21-2006 04:19 AM
