Old 01-31-2006, 02:27 AM   #1
sboy
sboy is on a distinguished road
Default engine problem...
hi guys, im a newbie. ive been using my supra '87 for almost 2 yrs now. ive been experiencing engine stalling (7MGe). everyday i'll use it, i have to let it the engine run for about 10-15 minutes or so. if i will not do that, it seems like there is no power even when i stepped on the accelerator. what would be the problem? Thanks a lot guys.
sboy is offline   Reply With Quote
Old 02-01-2006, 04:48 AM   #2
stumpjumper
stumpjumper is on a distinguished road
Faulty distributor; seriously clogged injectors or faulty injector; worn fuel pump; crapped out ignitor; seriously in need of a tune-up; maybe a sensor is malfunctioning. Just gotta check each thing one at a time. No check engine light I presume?
stumpjumper is offline   Reply With Quote
Old 02-01-2006, 11:15 AM   #3
Strannik
Strannik is on a distinguished road
doesn't supra have coil packs instead of distributor?
Strannik is offline   Reply With Quote
Old 02-01-2006, 01:50 PM   #4
rnoswal
rnoswal's Avatar
I am not sure about this but when I had low coolant because of a leak, the car would act the same. I am sure mine was because the sensor didn't pick up the warm water and never registered anything but cold. So it started rich and always bogged, hesitated so bad it was very hard to drive. That may be your problem, a cold start sensor going out. Of course that is just my guess and I don't know if a bad sensor like that puts out a code.
Let us know.
Russ
Old 02-01-2006, 06:24 PM   #5
j3pz
the NAs have a distributer, turbo models have coil packs and cps
Old 02-01-2006, 10:25 PM   #6
sboy
Let us know.
Russ
yeah, i think that's my problem. when my engine starts, my rpm was high but i think it is normal for the engine to make the water temperature stable, but for my engine it takes a long time. oftentimes, i have to open the hood and to check the radiator if it is hot enough. what sensor do i have to change? if its the water temp sensor, which one is it? where it is located?
BTW, thank u again guys!
Old 02-03-2006, 01:09 AM   #7
sboy
iam still in need of ur advice guys....thanks.
Engine Problem 86toySupra MKIII Supra 3 04-17-2007 04:50 PM
engine problem nickalvrz Non-Generation Specific Questions 5 10-16-2006 02:51 AM
Engine problem malli Non-Generation Specific Questions 3 08-01-2006 12:44 AM
Jdm engine rev problem Wicked19 MKIII Supra 3 11-08-2005 02:42 PM
