Old 02-01-2006, 08:12 AM   #1
87supraturbo
87supraturbo is on a distinguished road
Default Head and Block Machined??
Alright, at the risk of sounding like a total noob(which I am), when you are replacing with a metal headgasket, and your current one hasnt blow, do you have to have the head and block machined? And the whole engine needs to come out for the block to be machined, correct?
Thanks,
Matt
K&N FIPK
87supraturbo is offline   Reply With Quote
Old 02-01-2006, 08:33 AM   #2
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
Default Prepping for a Metal Head Gasket (MHG)/Multi Layer Steel gasket (MLS)
Yes, both need to be machined to get an RA of lower than 50 for Cometic (as their tech staff recommends) and even a lower RA for some other HG makers.
Lower RA's = smoother surfaces. It is not like with sand paper ratings: with RA's (roughness average), the lower numbers are a smoother surface.
Some do lap the block, but I am very much against that because lapping may not create quite as flat a surface as milling. Not only must the surfaces be smooth, but they have to be very flat.
Another method:
IF you really wanted to use a MHG without having it machined, some people are using Permatex Brake Quiet and spraying that on to help aid in the sealing since this material will conform to very small surface irregularities.
Some do just go ahead and not go by the manufacturers' recommendations of having the block milled. Some of those have had luck--although it is not recommended that way. Although some had luck without milling, it is not the book as the proper way to set up for a MHG. You would be taking a chance not going by the proper recommendations.
TONY! is offline   Reply With Quote
Old 02-01-2006, 09:27 AM   #3
kewlcoconut
kewlcoconut is on a distinguished road
im also in the process of replacing my HG. you mentioned "Permatex Brake Quiet", but I heard that a copper spray works good as well because it has high heat resistance. which would you recommend that works better?
kewlcoconut is offline   Reply With Quote
Old 02-01-2006, 11:14 AM   #4
Strannik
Strannik is on a distinguished road
use copper spray
and i would use it not only on headgasket, but on other gaskets as well (like intake, exhaust etc...
Strannik is offline   Reply With Quote
Old 02-01-2006, 02:06 PM   #5
rnoswal
rnoswal's Avatar
Almost no head gaskets require any adhesives at all. They are not recommended. If you need clamping power then go with ARP studs. Metal gaskets are usually only for the turbo engines. A FelPro head gasket works just fine in an N/A.
If you do pull the engine, make sure you keep the front aluminum cover on the engine so it can be milled too.
As I said before inanother posting. Don't worry about buying an extra thick headgasket either if it is a N/A engine. The extra compression helps and the cams are easy to retime with the adjuster holes in the cam gears.
Russ
Old 02-02-2006, 03:47 AM   #6
TONY!
TONY!'s Avatar
The Permatex Brake Quiet also has a high degree of heat resistance. Brake pads get really hot too.
The Permatex Brake Quiet is being used by some of the more experienced guys.
One of those guys put down like 900 HP at Vegas.
From the 4 guys that I know who have used it, they highly recommend it.
Originally Posted by rnoswal
Almost no head gaskets require any adhesives at all...
From the first statement statement, it implies that so some actually do recommend using a sealant. I was not aware that any manufacturers recommended a sealant at all. I know that Cometic does not.
… They are not recommended…
What is recommended is that the head and the block be milled to a low RA. Some are not taking the block out, in that case, they are not following the manufacturer’s recommendations. If the block is not to be taken out, to get a low RA, then yes, Permatex Brake Quiet will be of great help. Some are even using it whom have had their blocks milled anyways.
…If you need clamping power then go with ARP studs…
Clamping power is not the same as good sealing. Ideally, people should be going with ARP studs anyways, but clamping power will not fix surface irregularities. People do get BHG’s even with lots of clamping power.
All that said, use whatever you fancy.
Old 02-02-2006, 02:55 PM   #7
Idaho
Idaho is on a distinguished road
Hi, I apologiye for mz english, but can you specify Permatex Brake Quiet " ??
I don't know what to udersatnd uder this term..
thanks..
Idaho is offline   Reply With Quote
Old 02-02-2006, 10:44 PM   #8
kewlcoconut
well, there is a company called "Permatex", and they make a product called Brake Quiet. you spray it on your brakes to quiet them. But this can also be used on Gaskets as a sealer when you rebuild your engine. It has high heat resistance, and works good to seal them.
Old 02-02-2006, 11:11 PM   #9
TONY!
TONY!'s Avatar
thanks..
Well the "Permatex Brake Quite" is used to seal up imperfections to decrease the likelyhood of getting a BHG. If you just can't get your block machined, but have determined that the block is straight and not warped without too big of surface imperfections, this may be the way to go.
You would buy the spray can type (it also comes in a tube, but that is not what you want) and put on 2 spray coats on each side.
Spray the gasket while it is hanging so that you can spray both sides evenly that way.
Let dry for about 15 minutes and then start assembling things.
The following is a picture of a can:
I also took a picture of a MHG that had this sealant on it (in the attached pic).
It is not my build up, but is my friend's (shaeff's).
He won't mind me using that pic, since I was the one that took it in the first place. heheh
EDIT:
Didn't know you had already replied, kewlcoconut.
You did it while I was making this post. heheh
Old 02-02-2006, 11:26 PM   #10
mrnickleye
mrnickleye's Avatar
Wink Carefull, there are noobies around.
kewlcoconut said......."well, there is a company called "Permatex", and they make a product called Brake Quiet. you spray it on your brakes to quiet them".
He meant on the back side of the brake pads, before installing them. DO NOT just spray this stuff onto your brakes. (believe me, I've seen it done, and its not a pretty site).
7MGTE block and head TxSpeedBoy Import Auto Center 4 07-01-2009 06:33 AM
7mgte head on 7mge block? RCSG_MK MKIII Supra 4 01-01-2008 02:01 PM
5M head onto 7M block mattapo MKII Supra 1 05-09-2007 03:49 AM
Head Gasket Part II Bullz_EyE MKIII Supra 2 01-26-2006 06:30 PM
Milling head and/or block kazam Non-Generation Specific Questions 0 07-31-2005 11:19 PM
