#1 |
Sup, well apparently I need new brakes, rotors and tires. I am just going to put on basic 4 season tires for now, since ill be upgrading rims later. But to install and purchase all 4 rotors, all 4 pads, and all 4 tires the mechanic is trying to say around $1,000. This seems a little pricey to me. Maybe I'm wrong. But I found on eBay '88Rotors' Cross-Drilled/Slotted Rotors front and back and pads for $249. Is that about right?
link: http://cgi.ebay.com/ebaymotors/86-92...spagenameZWDVW Any help here would be great, I'm chomppin at the bit to get this car back and start throwin in audio/security. And I do not know what size tires, grade, performance. All i know is they were 225s on there before. Stock rims. So i'm assuming hes jsut replacing. TIA |
#2 |
Those rotors and Pads look like a good deal on ebay.
Be sure to bed them in.... http://www.zeckhausen.com/bedding_in_brakes.htm If you brought in the parts to my shop, I would charge you $225 labor, because you didn't buy them from me, so I didn't make any $$ on the parts. So if your guy charges $225 or less, its still a better deal, because those rotors are better than aftermarket stock ones. Also...tires.... http://www.discounttire.com/dtcs/home.do Don't do what I did, if you ever want to go larger rims, do it when you get tires. I ended up getting 16" tires, then rims 6 months later, so I have 16". It would have looked better with 17".
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. |
Thread Tools | |
Display Modes | |
Two Issues: Front Brakes and Sporadic Vibration | Chambers | MKIII Supra | 0 | 11-03-2007 04:15 PM |
Slotted Rotors | IHateHacks | MKIII Supra | 5 | 07-10-2007 11:30 PM |
13 inch Wilwood MKIII front brakes | ARZ | Arizona Performance | 0 | 03-16-2007 07:57 AM |
Brakes 5M Vs. 7MGTE | panda-supra | MKII Supra | 3 | 03-22-2006 09:07 AM |
Brakes acting up | maksimus54 | Non-Generation Specific Questions | 4 | 07-06-2005 11:47 PM |
