Old 02-08-2006, 04:45 PM   #1
darkzebra
darkzebra is on a distinguished road
Default Really SLOW acceleration under D
I just bought a 1988 Supra Turbo for my 16 year old son.
The car seems to have one mechanical(?) problem: it accelerates normal under R, L, 2, but creeps (really creeks) under D
Motor sounds fine during idle. There is no overheating or apparent head gasket problem.
darkzebra is offline   Reply With Quote
Old 02-08-2006, 09:21 PM   #2
XtreeX
XtreeX is on a distinguished road
I'm having the same problem with my 1990 N/A Supra. Feels like I'm giving it tons of gas but it's just not moving. Granted it's not a turbo, but still...
I took it in to have the timing belt checked out and they said it was fine. Next step is just having the catalytic converter looked at, it sounds groggly... So it it's jammed up inside then I'm just going with a all new exhaust (straight pipe).
Anyone have any ideas what else it would be? HG is fine and all pumps are in working condition, no leaks, all hoses replaced.
XtreeX is offline   Reply With Quote
Old 02-08-2006, 11:46 PM   #3
mrnickleye
mrnickleye's Avatar
Either take it to a shop and have the EXHAUST back pressure tested, or unbolt the exhaust pipe from the manifold and drive it to see if it improves. A plugged exhaust can give a NO power situation.
Old 02-10-2006, 04:42 AM   #4
rnoswal
rnoswal's Avatar
Sounds more like a transmission problem than engine, especially if it runs fine in the other gears.
Russ
Old 02-11-2006, 03:30 AM   #5
darkzebra
I thought about tranny, but I can't understand why it would work normal in L and 2, and not in D.
Isn't L and 2 the same physical 1st and 2nd gears under D?
Old 02-11-2006, 04:40 AM   #6
rnoswal
rnoswal's Avatar
Well your selector may be out of adjustment and for some reason not starting out in 1st gear when put in D. Or it might be an internal problem. But if it runs pretty good in the other two gears then I would count out the engine as being a problem.
Russ
Old 02-11-2006, 11:49 PM   #7
mrnickleye
mrnickleye's Avatar
Wink
When you drive the car in 1st or 2nd, if you can rev up to 5k rpm for a few seconds, then the exhaust is not likely clogged. Also, if it does this smoothly, without misfires and stumbles, then the ignition and fuel system are likely ok.
So...if it seems sluggish in D (drive), then likely the transmission is starting out in 2nd or 3rd.
That would be likely be either a ETC (electronic Transmission Control) computer, or shift solenoid problem. It can be diagnosed by a reputable tranny repair shop. There is a very good chance that it can be repair without a complete overhaul.
The problem for you also is....finding a shop/technician that KNOWS how to diagnose. Most just want to rebuild, figuring that it will get fixed along the way.
The same is true with engine electronic problems. Finding a KNOWLEDGABLE tech can be frustrating, and costly.
Old 02-12-2006, 04:51 AM   #8
ComptonsF1NEST
ComptonsF1NEST is on a distinguished road
i know in Hondas some of the Shift soleniods in the auto trannys will go bad and make the trans skip gears and do weird stuff.
take it back and buy a 5 speed
ComptonsF1NEST is offline   Reply With Quote
Old 02-12-2006, 05:21 AM   #9
XtreeX
Taking it back isn't the answer, I like having an automatic. For my car, the acceleration isn't abysmal, just a little slow. I'm going to get a new exhaust and we'll see if that fixed it. If not, then I'll have to look deeper in the transmission.
Old 02-12-2006, 05:37 AM   #10
rnoswal
rnoswal's Avatar
I was just curious about something. If the car accelerates normally in R, 1 and 2 but not in D, what happens if you start the car off in D and it starts its creeping, then you pull the shifter back to 1, does it accelerate normally, quickly again? And if you put it in 2, does it shift twice or just start in 2nd and stay there?
Russ
push down pedal - slow acceleration (HELP!) hockeygott MKIII Supra 7 06-30-2008 05:40 PM
Slow Start jaysun MKIII Supra 5 09-18-2006 07:36 AM
Super Slow on D, L and 2 ok ram5757 MKIII Supra 1 04-20-2006 06:15 AM
slow acceleration 87supraguy MKIII Supra 2 03-19-2005 07:47 AM
