turbo
i have a 1988 supra and want to turbo it really bad but do not have a very big budget due to that i am only 14 years old and was wondering how much money it takes to ge one up and running and about 9 psi i would be very happy if some one could help me with this
What is the legal driving age where you are? Have you even enjoyed it yet? It may have more than enough power for you as it is now. Eh, whatever. The cheapest way would probably to buy the parts you need from someone parting out a car with those parts. You still need to deal with the issues of oiling the turbo since the NA block is not set up to deal with the turbo's oiling needs. You need to either tap into your current block or get another one. You will need an oil pan ($25), 440 cc injectors ($50), turbo (about $130), turbo feed/return line ($15), turbo elbow ($20), probably a different exhaust ($?), possibly a CPS?, possibly a different fuel pump, I should know if the fuel rails are different along with the pulsation dampener and fuel pressure regulator since I do sell those--but I am not sure about that, AFM (about $85ish), ECU for the turbo $85, intercooler and its piping ($110), BOV ($15)and many other stuff probably. I listed the parts that are stock since I have dealed them out or will deal them out. Or you can just buy an engine from a JDM shipper whole for about $1100 plus shipping, and then get the ECU. I am pretty much a "if it is not broken, don't mess with it kinda guy," I suppose...happy wrenching if you go that route though. |
Get a good set of headers, good exhaust, better airfilter and make sure the timing is good, maybe advance it some and use high octane and you will have a very fast N/A. I know, I have one and it is very peppy.
Otherwise sell this one a buy a Supra with the turbo already installed. Much easier to modify that way. Russ |
im in the same situation as this kid. but i dont want a 130$ turbo. im looking for somthing with a little more meat. so what do i need?
