Old 02-20-2006, 10:50 PM   #1
MattJ
MattJ is on a distinguished road
Default Buzzing Auto transmission
Hello,
The auto 'box has started to buzz recently, seems to do it whatever 'shift' i am in? Sometimes it's not there then it starts and stops. There are no problems with selecting gears etc.
Wondering if it might be a heat shield or something?
Matt
MattJ is offline   Reply With Quote
Old 02-21-2006, 02:06 AM   #2
It may be a vibrating shield on the exhaust, very common. If you have some ramps, get it up on them and feel around (when cool) to see if you can find something loose. If not, have a friend rev it up and down while you look under there for a possible loose shield.
Old 02-21-2006, 10:40 AM   #3
MattJ
Thought it might be something like that was not sure if there was a heat shield around there so i'll check it out, thanks
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Auto Transmission Swap big_kahuna89 MKIII Supra 1 06-13-2008 11:13 AM
Auto Transmission Shifter Question 87 Supra MKIII Supra 4 09-18-2007 07:20 PM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
