#1 |
I Have A Vibration Problem With My Supra (mk3), Everytime I Hit 50 Miles Per Hour The Car Starts To Vibrate, The Vibration Is Coming From The Back Of The Car, Is Not From The Front (engine), Can Anyone Help Me To Solve The Problem.
#2 |
Tires, alignment..
Those'd be the first thing I checked. Have the tires sat for a long period of time? How long has it been since you had a front/rear alignment? Do you drift the car? Tapped a curb? Things like that. |
#3 |
If a bushing is bad, the play in it can cause vibrations. If it a steady one, at 50-60mph, and there are no signs of tire tread seperation, then out-of-balance tire can cause it.
If it just 'showed up', then tire tread seperation is a very strong posibility. Jack up the tire and place car in neutral, then rotate the tire by hand while looking closely for a 'high' spot in a section of the tread. Usually about the size of your hand. If oyu can't find the problem, put the back tires, one at a time, on the front. Test drive to see which tire it might be. Then do other tire.
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. |
ABS Problem? | rasclaat_98 | MKIII Supra | 6 | 12-13-2010 09:53 PM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
found the problem | brs86supra | MKIII Supra | 0 | 05-02-2006 03:42 PM |
Boost Problem, I Guess | nonstop213 | MKIII Supra | 0 | 02-23-2006 07:32 PM |
Nasty Tailshaft Vibration - Please Help! | CNS45 | MKIV Supra | 2 | 12-22-2005 11:35 PM |
