Old 02-26-2006, 04:29 PM   #1
thesandymancan
thesandymancan is on a distinguished road
Default shift points
what are the optimal shift points for the 7mgte?
thesandymancan is offline   Reply With Quote
Old 02-26-2006, 06:27 PM   #2
kwnate
It makes 230hp at 5600rpm, after that being all stock it seems to taper off. When I was stock I usually shifted around 5600 and it would stay in the powerband. Running it to redline when stock I think will just slow you down. Just experiment with different levels and use the shift point that feels best.
Nate
Old 02-26-2006, 06:28 PM   #3
TONY!
TONY!'s Avatar
Depends on what kind of driving you are doing.
For racing, you would want to try to keep your RPM's in the highest part of the powerband.
For normal driving, you would want to keep the RPM's between 2000 & 4000, with 3000 being about ideal for highway use.
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
Old 02-26-2006, 06:47 PM   #4
thesandymancan
thanks. i have been shifting at abot 5000 when i wanted to push it. i just wanted to for when i ran 1/4mi times.
What RPM do you shift at? ogkush Road Racing & Autocross 5 11-04-2010 07:58 AM
shift knob D_Train MKIII Supra 9 06-29-2007 09:16 PM
It won't shift & speedo quit! bksackrider Non-Generation Specific Questions 3 03-19-2007 10:24 PM
