Old 03-07-2006, 01:39 AM   #1
XtreeX
XtreeX is on a distinguished road
Question Exhaust for 7mg(t)e
Hey guys...
I will be doing a swap (7mgte) in the next year or two but need a new exhaust, stat! Will getting a 3" exhaust right now be bad for the n/a side of it? I guess i just don't want to buy a 2.5" muffler and cat and piping, then have to get a whole new exhaust shortly down the road... it'd be money wasted in my opinion. So my question I guess is, what exhaust setup would do me suffice now and with the 7mgte?
Thanks... sorry if thats a little confusing?!
XtreeX is offline   Reply With Quote
Old 03-07-2006, 01:49 AM   #2
XtreeX
Will running a highflow cat, 3" to muffler be bad? Even if it's only for a year or two?
Old 03-07-2006, 03:01 AM   #3
supra_91
supra_91's Avatar
i don't see why it would hurt it. if you don't get tested for emissions i would run with a test pipe instead of a high flow cat. there is a thread in here somewhere on exhaust systems, i'll have to find it and post it
Old 03-07-2006, 03:03 AM   #4
supra_91
supra_91's Avatar
here it is....hope this helps
http://www.toyota-supra.info/forums/...read.php?t=957
Old 03-07-2006, 03:55 AM   #5
XtreeX
Yea i read that awhile ago. Liek i know what i would put on it if i were going to stay n/a, but i think that im going to put the 7mgte in for sure now and that kinda changes my plans... with headers as well. Because I cant put the OBX headers for the 7mge on the 7mgte... correct?
Old 03-07-2006, 04:43 AM   #6
mrnickleye
mrnickleye's Avatar
Correct on the header issue. You could use 3" everything back. You just will loose some torque on the launch, but can gain some high end. But I would not be reving past 6500rpm anyway.
For me, mostly around town, I like the torque on the bottom. Quicker 0-60.
If you do put a header on now, you could always sell it here after you do the turbo swap.
Cat conv does give you some (?) back pressure for the n/a.
If it were me....I would go 3" with a 3 chamber magnaflow muffler to get some back pressure. It would be plenty of sound, and I've read of others with turbos use it just fine.
Old 03-07-2006, 09:39 AM   #7
XtreeX
ohk. so get the headers now, sell them later. I can do that. I'll just keep them as clean as possible over the span.
Then get a high flow cat, 3" custom exhaust to a 3" magnaflow muffler? Sounds like a plan. This summer its paint job/body work... and manual conversion... then next summer i plan on doing the swap. I'll have to suffer threw low end loss for the time being. it'll be worth it in the end financially.
Thanks fellas. I think that's it?
Old 03-07-2006, 06:08 PM   #8
hangsupra
get a 3" cat back with a 6"muffler for a high flow.... thats what i use on my mk2 turbo.
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
Exhaust Cat Fitting Bill UK MKIII Supra 4 06-15-2008 11:32 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
Dual exhaust, anyone? lifesnotfair MKIII Supra 13 12-22-2005 10:41 PM
