Found a "seeping" HG on the exhaust side of cyl. no. 6. It wasn't burned, just distorted and pushed out toward the water jacket a little. Guess I caught it early. Previous owner had tightened all the stock head bolts to "at least" 70 ft. lb., and all were still good and tight.
Took the head to a very reputable cyl. head shop here in Phoenix (Bill's Cylinder Heads) where they checked for cracks and then machined the head flat. Had to remove .009" to flatten it. I think that's NOT a lot to remove on such a long head, right? The "chief" head man there told me they've sold and used Fel-Pro HG's and never had one leak, and he's seen and done a LOT of Supra heads. Told me the Fel-Pro has a steel internal layer and some kind of graphite layers on the outsides, and they're far better than stock HGs. I'm planning on getting ARP head BOLTS rather than studs. I'm not a big fan of studs vs bolts-I've seen many good bolted connections used in very critical (nuclear) service. "It's the preload and maintaining it that counts". Any comments?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein 1988 and 1990 Turbo Supras Last edited by Benesesso; 03-10-2006 at 03:16 AM. |
1990 supra turbo engine issues help | jespat | Non-Generation Specific Questions | 4 | 01-24-2008 02:37 AM |
head gasket gone would it give oil in turbo intake | johnkarl | MKIII Supra | 7 | 10-31-2006 06:38 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
