Old 03-11-2006, 04:30 PM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default Need Help Loose Connector
As the title says, I took some pictures of a connector I cannot figure out where it goes. Any help is appreciated.
Wire colors are Black/Red and Green/Black.
56'kers Beware. Pics are huge.
Follow the link.
http://www.speakeasy.org/~mikik/Supra/
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 03-11-2006, 04:42 PM   #2
nickvash0104
nickvash0104 is on a distinguished road
I believe that goes to the VSV on the underside of the intake manifold.
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
Old 03-12-2006, 03:47 AM   #3
Dejvid1785
Is it somewhere close to the starter? Can you tell me exactly where it is? Its hard to see it because of the intake manifold.
Old 03-12-2006, 01:57 PM   #4
nickvash0104
http://www.cygnusx1.net/supra/library/TSRM/ec/EC_03.gif
Try that... it is located underneath the intake manifold in a very bad spot. My wiring harness had broken and I was forced to try and splice the wires - I think that was one of the hardest things having to be done while leaving all of the parts on!
Even if yours is a GTE engine, it's in the same location.
Let me know if you find it, I've got my block apart for a swap, just waiting for the JDM, so I can always go find it on the harness.
Black '87 N/A Auto
Old 03-13-2006, 11:39 AM   #5
if you have egr you may have two vsv's under there
but it should be under/between #1 & #2 intake runners
Old 03-13-2006, 02:27 PM   #6
rnoswal
rnoswal's Avatar
I just noticed how rusty colored your cams look. Is that sludge or has it been sitting up for a while. The intake looks nice and clean though, hope the rest of the inside of the engine doesn't look that way.
Russ
Old 03-15-2006, 04:32 PM   #7
Isphius
Isphius's Avatar
that also looks like it could go on the water temperature sensor on top of the thermostat....but it would be easy to see. i think toyota likes connectors that look like that. also does anyone know if the water temperature sensor sends to the gauge in the car? because my stopped working.
Old 03-15-2006, 08:46 PM   #8
that plug def goes to one of the vsv's under the intake
as for your temp issues... there are two temp senders located on the thermostat housing, one is a two pin plug and usually green or grey depending on year.. that one is your ecu temp, the other one is just a single spade terminal (and if it's old) where the spade terminals comes out the sender will be a reddish colour and breaking into smallish pieces thats your dash gauge
well... here's a grayscale one lol
http://www.rockauto.com/ref/SMP/SMPD....html?TS73.jpg
Old 03-16-2006, 02:10 AM   #9
Isphius
Isphius's Avatar
thanks. i think you (suprra_girl) and several other people make this one of the most usefull forums in the world...haha.
what a loose battery ground clamp does ghost88 Non-Generation Specific Questions 0 02-25-2009 04:42 AM
what connector is this?? burton51m MKIII Supra 10 06-16-2008 01:06 AM
loose lifters? mk3000 MKIII Supra 6 06-08-2007 11:07 AM
Loose shifter, missing coolant! XtreeX MKIII Supra 13 10-23-2006 07:13 PM
loose wires 87supraturbo19 MKIII Supra 10 01-19-2006 05:51 PM
