Old 03-31-2006, 10:16 PM   #21
kewlcoconut
kewlcoconut is on a distinguished road
bahhh.....i still havent figured out this problem. im going to get a fuel pressure test soon. but also, would a bad gas cap do this? not venting properly??
kewlcoconut is offline   Reply With Quote
Old 04-03-2006, 12:53 PM   #22
brs86supra
brs86supra is on a distinguished road
just replaced my afm and it still does the same thing, cant seem to figure it out. this problem is killing me, what could it be
brs86supra is offline   Reply With Quote
Old 01-15-2007, 08:46 AM   #23
yellowturboman
yellowturboman is on a distinguished road
Did you guys ever fix this problem? I have it too!
yellowturboman is offline   Reply With Quote
Old 01-15-2007, 10:40 AM   #24
mr.w
mr.w is on a distinguished road
I have this problem too, I just hold the gas a little when I start it up and after a couple second of holding it it will idle around 500-800 rpms. If I don't hold the gas while I start it up the engine starts and staggers to get to the right rpm but will stall out. Also starting it when its cold the engine will start and shoot to 1100-1500 rpms. My car is a 87 turbo. I want to replace the fuel filter to see if that will fix it and because it probably needs replace, I also need the check the air filter. Im pretty sure the injectors and that are okay because I had some one do the head gasket for me recently.
mr.w is offline   Reply With Quote
Old 01-15-2007, 04:20 PM   #25
yellowturboman
yeah thats exactly what mine does, hold the revs up a bit and it goes away, only does it when engine warm though maybe halfway between hot and cold marker. If you leave it to cool right down it will start no probs. Was thinking maybe it is a miss fire in engine caused by maybe silicon hoses arcing when they get warm or somthing. Im going to give it a full service and see if it goes away.
If anyone has had this problem and fixed it can you please please please tell me what it it. Thanks
Old 02-07-2008, 06:08 PM   #26
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
I have the same problem I think it would be leaking fuel injector in the morining or when the car is cold it needs the extra fuel to start. When you get back to your car from going in its still warm it doesnt need the fuel so it floods it out causing it to run bad. Take out the dip stick and smell it if it smells like gas it is the injectors more than likely, also let it sit and idle for about 15 mins if it starts running bad and missfiring then you have the same problem I have. And I put a new gas tank filter and pump on my car 6 months ago. mabye this will help. btw I havent replaced my injectors yet.
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
Old 02-09-2008, 08:38 AM   #27
SilenceboneSupra
SilenceboneSupra is on a distinguished road
i had a similair problem like that! it was hard to start at all times and it would die fast if i do not keep it over 1000rpm, found out that the first fuel injector gave up for some reason which i think was the cause, after getting myself new VENOM fuel injectors it worked out great but i dont know if it this is the same problems u guys have........................
SilenceboneSupra is offline   Reply With Quote
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
