#1 |
I have an 87 turbo and an 87 N/A. The N/A's A/C stopped working, but it was just a fuse. I thought it might have been the dash unit at first though for some reason and tried a few different ones I had. They all worked fine as far as speeding up the engine when the A/C was turned on and once I replaced the fuse all was good.
Now my Turbo is another story. If I turn on the dash A/C button, nothing at all happens, so I tried the other control boxes and they all reacted the same, nothing happened. If I hot wire the compressor it works just fine. When I got the car the A/C wasn't woking because of a bad compressor. I replaced it and charged the system. Is there a fuse for the A/C or another controller I am missing? The same fuse in the N/A is working in the turbo, but the panel doesn't say A/C fuse, neither did the N/A panel for that matter. Any clues out there? Thanks Russ |
Thread Tools | |
Display Modes | |
Question about 7m-gte. | AzNbOi2626 | MKIII Supra | 3 | 03-29-2011 06:55 PM |
Starter Removal question | OkieRA29 | MKIII Supra | 13 | 05-11-2010 12:08 AM |
Pre89 versus 89+ nose and support. | lifesnotfair | MKIII Supra | 2 | 01-08-2010 09:06 PM |
Help! Question on front NOSE and bumper supports. | lifesnotfair | MKIII Supra | 1 | 12-26-2005 03:54 PM |
Quick question | AutoXMan | MKIII Supra | 12 | 09-30-2005 06:40 AM |
