Old 03-14-2006, 09:35 PM   #1
Supra-Boy
Supra-Boy is on a distinguished road
Default 87 Supra 7M-GTE/AT Engine cranks over but doesnt start...
Hey! I have a 1987 toyota supra with turbocharged engine, that I just bought
owner told me that it have "BHG" I took out that engine and Installed another same 7M-GTE... But it doesnt start I get spark and spark plugs are wet...???
and another thing engine cranks up too fast not like on my other supra... I mean it spins too fast not like normal and It still have compression.. could it be the camshaft position sensor not in the right spot??? because I tryed to ajust but still no start.. and its have automatic transmision..
Please Help!!
Thank You!
Supra-Boy is offline   Reply With Quote
Old 03-14-2006, 09:59 PM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
if you have spark... then your plugs shouldn't be wet
you missing one or the other i would imagine
verify your timing with the links i posted in this thread
http://www.toyota-supra.info/forums/...9141#post19141
then let us know if there is any change
Pics of my build.
Do a diagnostic first!
Old 03-14-2006, 10:39 PM   #3
Supra-Boy
I have spark "fire" and spark plugs are wet "gasoline" but It doesnt start up..
me Confused...
Old 03-14-2006, 10:50 PM   #4
suprra_girl
7M POWAH! ;)
what have you done to verify you have spark?
did you pull a lead out and try one of "your" plugs in it or did you use a spare plug you have
if your plugs are firing
that means the plug won't be wet as the fire evaporated it
how many cylinders did you check... all of them?
check all your plugs to make sure they aren't faulty
Pics of my build.
Old 03-14-2006, 11:08 PM   #5
Supra-Boy
Smile
Well I took off spark plug from #1 cylinder and put it on valve cover and crank up engine it fired.. and last cylinder #6 and it fired too, I used spark plugs that were in the car not spare ones... and it even sparked when I put the wire with plug on the valve cover without the spark plug...
Thank You for your help!!
Old 03-14-2006, 11:59 PM   #6
suprra_girl
7M POWAH! ;)
try #'s 2 & 4
as 1 & 6 are on the same coil so 6 will fire if 1 is
have you checked your timing?
Pics of my build.
Old 03-15-2006, 12:05 AM   #7
Supra-Boy
try #'s 2 & 4
Hey! Okay I will check #2 and #4 tomorrow and timing too and I will let you know...
Thanks again =)
Old 03-15-2006, 11:38 PM   #8
Supra-Boy
Thanks again =)
Well I just checked #2 and #4 cylinders they both have spark.. and timing is correct, Now looks like it doesnt get gas thru injectors.... I have no clue whats wrong with it now.... Do you know what it might be? or anyone else??
Please help!!
Thanks...
88 Supra.. body work and engine question - quickies : ) Grandavi MKIII Supra 5 10-08-2010 04:58 AM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
