Old 06-27-2010, 12:41 AM   #1
Rahnter
Rahnter is on a distinguished road
Default Oil on spark plugs
My car has been misfiring at random times during the last week or so. Decided to take a look today, and found a small pool of oil around spark plugs 1/2 & 5/6, pugs 3/4 were unaffected . I cleaned the area as best I could and pulled the plugs, and the were covered with motor oil (may leaked down since it was hard to clean it all). I didn't see any leaks from the valve covers (had the gaskets replaced about 2-3 years ago). I'm going to take another look tomorrow, but what do you guys think? Any help is appreciated
Rahnter is offline   Reply With Quote
Old 06-27-2010, 01:04 AM   #2
mirage83
That's your #3 gasket leaking in the plug galley. Easy to replace with the OEM gasket, or you can use generic washers/gaskets of a size I can't recall right this moment . Just pull the bolts which hold that gasket on and replace, should resolve the problem of oil getting into the plug galley and shorting your plug wires.
Old 06-27-2010, 02:23 AM   #3
mirage83
BTW, the four bolts you have to pull are 14mm allen head bolts. The gaskets I mentioned earlier (if you don't want to go with a new #3 cylinder head gasket) are oil drain plug gaskets. Take one of the bolts with you to a auto parts place and find a suitable size.
Old 06-27-2010, 02:40 AM   #4
907mge
907mge's Avatar
You don't need to replace the 4 plugs. On mine I did away with the spark plug valley cover and just reinstalled the plugs with RTV and it has worked very well for me. I also cleaned up the treads well. I left the cover out so I could keep track of what is in the valleys since the coolant plugs can leak also.
Old 06-27-2010, 04:13 AM   #5
mirage83
Yeah, didn't realize that I had left a couple of words out as the bolts definately don't have to be replaced. Was thinking faster than I was typing.
Old 06-27-2010, 09:37 AM   #6
batmmannn
batmmannn's Avatar
Default Those plugs
Be careful putting them back in I also used RTV and it worked great I have no oil leaks. Don't strip them going back in and not too tight. By the way guys my red Supra is still going strong!
Help...My spark plugs are in the oil !!! chinesedawn MKIII Supra 6 10-03-2011 09:25 PM
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
