-   -   cam shafts turbo, n/a need help with this asap (http://www.toyota-supra.info/forums/mkiii-supra/3958-cam-shafts-turbo-n-a-need-help-with-this-asap.html)
87nasupra 03-18-2006 08:08 PM
ok i have a 1987 n/a supra i got cams from a 1987 turbo supra i want to install them from what i have heard they will fit fine and should move my powerband forward a bit but they should drop right in with no problems is this correct has anyone done this or heard of someone doing this people let me now
88Supraboy 03-18-2006 08:16 PM
the cams for the N/A and turbo are almost the same, the intake cam on the N/A is a tuch more agressive, but barly. you probley wont notice a difference between the two. And you can swap them, there the same.
87nasupra 03-18-2006 08:26 PM
so both cams are good to go a head and replace?
Levi1717 03-19-2006 03:18 AM
Heads?
is there ne differents in the heads of the turbo and non turbo.
