Old 03-19-2006, 07:07 PM   #1
DarkRaiderz
DarkRaiderz is on a distinguished road
Unhappy Whistling Noise
THERE IS A WHISTLING NOSIE COMING FROM MY ENGINE
I DO NOT HAVE A TURBO THE WHISTLING IS COMING FROM THE RIGHT FRONT AREA WHERE MY CLUTCH FLUID GOES AROUND THERE
1986.5 Toyota Supra Non Turbo
DarkRaiderz is offline   Reply With Quote
Old 03-19-2006, 10:47 PM   #2
Troyota
Troyota is on a distinguished road
The right front is near the intake box...do you have an aftermarket air filter (K&N, ect.)? They will make a sucking/whistling sound when you get on the gas...that could be it...if it's actually the left rear (where the clutch fluid is), it may be a leaking gasket on your intake manifold...my best guess w/ the information you gave.
1987 N/A MA70 Supra <--1JZ swap in progress
1986 AE86 GT-S Hatchback
2002 DC5 RSX Type S
Troyota is offline   Reply With Quote
Old 03-20-2006, 10:28 PM   #3
DarkRaiderz
Question Whistler
NO No No 2 different things there is a suction noise that comes from the intake . but that is not the problem its a WHISTLING Literally Whistling Coming Frrom the LEFT Side Of my Engine
Old 03-21-2006, 02:14 PM   #4
rnoswal
rnoswal's Avatar
Get a hose small enough and long enough to put close to your ear and move it around to try to pinpoint the sound. Don't stick it in your ear in case you find it and it tries to suck out your eardrum, just close enough to hear. It could easily be a vacuum hose or even an intake gasket leak.
Russ
Weird noise from MK IV 5-speed tranny!! Help! Bone_Stock_Supra MKIV Supra 9 01-16-2008 08:35 AM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
exhaust noise toonen Non-Generation Specific Questions 2 05-19-2006 11:27 AM
Scratching noise in my '88 Black'88 MKIII Supra 2 03-24-2006 12:04 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
