Old 03-21-2006, 06:33 AM   #1
SCRAMJET
SCRAMJET's Avatar
Default oil pressure gauge problem....
I have an 86 supra which has had the 1jz conversion. Since the engine conversion, the oil pressure gauge hasn't worked. I believe it wasn't attached because the car the 1zj was taken from had a digital dash with no oil pressure gauge. Is it not too much trouble to get it hooked back up?
(1jz from a 93 soarer i believe)
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Oil Pressure Gauge mkiiisupra MKIII Supra 0 01-14-2008 02:08 AM
Oil Pressure Gauge Drag0na5h MKIII Supra 5 03-22-2006 07:25 AM
Oil pressure gauge Supra Guestalby MKIII Supra 0 04-23-2005 09:07 AM
