Old 03-27-2006, 06:38 AM   #1
SCRAMJET
SCRAMJET's Avatar
Unhappy Damn idle!
Can anyone figure this one out?
My car, when i start it from cold. It drives fine for about 3 or 4 minutes then, as soon as i bring the car down to idle, it wants to stall. If i let the car stall, no more idle problem after i restart it. If i don't let it stall, it will continue wanting to stall no matter how long i'm driving for. Any ideas?
Old 03-27-2006, 08:04 AM   #2
have you tried a diagnostic yet?
check in the faq's
let us know what codes you get
Old 03-27-2006, 08:07 AM   #3
SCRAMJET
SCRAMJET's Avatar
Talking
That would be a good start only my engine light doesn't work. Maybe i need to rip my dash apart and fix it. Thats always fun...
Old 03-27-2006, 08:11 AM   #4
check out the bottom of this page
http://www.cygnusx1.net/supra/librar.../em/EM_04.html
Old 03-27-2006, 08:52 AM   #5
SCRAMJET
SCRAMJET's Avatar
Smile
gee, i hope i can get this all back together...
Old 03-28-2006, 07:57 AM   #6
SCRAMJET
SCRAMJET's Avatar
Unhappy
Well that was a waste of time... For some reason, they changed my dash when they put my new engine in. Where my engine light is, there is no actual spot for a light behind it. Where my engine light used to be with my old dash, there is an ABS light. My car doesn't have ABS. Obviously the car the dash came out of had. I would have thought every car would have had a spot for an engine light.
Old 03-28-2006, 08:30 AM   #7
dunno if this will help but here is usdm bulb locations
Old 03-28-2006, 12:46 PM   #8
SCRAMJET
SCRAMJET's Avatar
cheers but there is just no spot for a bulb behind where the engine symbol. It is on the bottom row of the set of LED lights on the right. Behind that, there is no spot for a bulb.
Old 02-17-2009, 01:15 PM   #9
RED1JZ
RED1JZ is on a distinguished road
you can goto ur diag box and wire from ts1 to E1 from memory and also wire a from b1 to ts2 with a LED inbetween it can act as a engine light i think check the other fourms
88 Supra
R154 Manual
1JZ Converstion Intercooled
Apexi Rampod
Hks TurboTimer
Blitz Nur Spec Zorst 3inch with hiflow cat to 4 inch cannon
Greddy Stage2 Elec Boost Controller 12psi...
Nxr 235/35/18s 245 on the back
Red Respray Black Bonnet
RED1JZ is offline   Reply With Quote
Old 02-17-2009, 11:16 PM   #10
Red1jz
Please make sure you are accurate before attempting to tell people how to do things electrically.
To do a diagnostic look in my sig, and this thread is donkeys old
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
HELP!!!!!!!.....1JZ wont idle!!!!! kuroi_tuki MKIII Supra 1 07-09-2007 12:41 PM
