Old 03-27-2006, 02:16 PM   #1
stuck1
stuck1 is on a distinguished road
Default timing issues
hey guys, new to the forum and have a problem that i coul use
some help on. have and 87 turbo with some timing issues.
19k on motor and i recieved the car with this problem. all
my timing marks line up cams and crank at tdc. when i jump the
diag connector to set timing and start the engine, i can't get
it to go to 10 degrees btdc. no matter how far i move the cam
sensor. when to sensor stops, that is 0 degrees tdc. wont go
any farther. i just cant figure it out. no vacuum leaks. new plugs
and wires. just wont work for me. any help would be much
appreciated.
stuck1 is offline   Reply With Quote
advanced timing? sd88supra MKIII Supra 7 04-27-2008 03:44 PM
Timing question. supramacist MKIII Supra 53 04-26-2008 11:41 AM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
