Old 04-05-2006, 01:01 AM   #11
Black'88
Black'88 is on a distinguished road
Originally Posted by rnoswal
I would just go to the parts store and buy a K&N stock replacement filter. It goes right in the original box, flows better and won't get wet.
As far as exhaust, the best way to go is with a good header and a larger, less restrictive exhaust system. The header will give you the best gains. Look for a good quatlity header, one with a good coating. The six cylinder sounds much better than a 4 cylinder engine, but if you can still get too annoying with the exhaust noise resonance inside the car with not a good enough type of muffler.
Russ
K&N stock replacement filter is better than any cold air system? How come all the highly modified supras I've seen have cai? And how would a cold air filter get wet?
Any recommendations/links to some high quality headers? Also, I've read that 2.5" is optimal exhaust size for a na engine car...Is this true?
Black'88 is offline   Reply With Quote
Old 04-05-2006, 01:20 AM   #12
j3pz
ive heard knn is best but i dunno... as for exhaust, ive heard between 2.5-2.75"
or 2.5-3"... dunno...lol im not much help.
Old 04-05-2006, 01:54 PM   #13
Jazzsaxsupra
Jazzsaxsupra is on a distinguished road
It could get wet because of the positioning of the filter. CAI filters are in a place that leaves them highly susceptible to spray from tires, other cars, etc. when it's raining.
I'm looking for a good header as well... I have an 86.5 NA Supra... suggestions would be amazing. :-D
Jazzsaxsupra is offline   Reply With Quote
Old 04-06-2006, 11:04 AM   #14
Burn N' Up
Burn N' Up's Avatar
Got any links for that aem system? I cant find any that fits a supra. Thanks!
There isn't one that fits the supra, but there IS one that fits the K&N FPIK. www.horsepowerfreaks.com sells a 6" inlet, 5" Element Dry flow that will fit the K&N FPIK setup.
If you want a cold air intake make sure to put a K&N Precharger or whatever its called on there, its like an anti-water condom for your Cold air to help reduce the risk of water getting on/in the filter, seriously though, CAI produces very little power for the risks.
FIPK Question Spdfrk1990 MKIV Supra 1 05-15-2008 09:08 PM
K&N FIPK installation guid with pics azerty MKIII Supra 1 05-04-2008 02:12 PM
Do a K&N FIPK NON-TURBO fit a TURBO??? 88supra_dude Non-Generation Specific Questions 1 04-24-2008 06:17 AM
K&N Air Filter D_Train MKIII Supra 6 01-04-2008 07:27 PM
FIPK Kit for Non Turbo? bpalmer21 MKIV Supra 3 10-13-2006 01:44 AM
