Old 04-03-2006, 09:34 AM   #1
SCRAMJET
SCRAMJET's Avatar
Default Differing on diffs
The LSD in my supra(86.5) is not working as well as it used to. On going to replace it, i was wondering which is the best diff for the car? I think it has a 4.3:1 ratio.
I know some later LSD diffs have around 3.7:1 ratio. Is there any advantage in the 3.7:1 diff? Seems you're just loosing out on acceleration for top end speed that you really don't need cause the car can fly easily off the clock with the 4.3:1 diff...
So which is the best?
Old 04-03-2006, 11:57 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
why not go for inbetween and get a 3.9
Pics of my build.
Do a diagnostic first!
Old 04-04-2006, 01:02 AM   #3
Burn N' Up
Burn N' Up's Avatar
dammit shes good
Old 04-04-2006, 03:19 AM   #4
kwnate
SP58GT
I'd stick with the 4.3, without a turbo it helps you get up and go alot better. You probably won't like the lost perfomance going with a 3.9 or 3.73.
Nate
Old 04-04-2006, 09:19 AM   #5
SCRAMJET
SCRAMJET's Avatar
i have the 1jz conversion so turbo's aren't a problem but i'd assume putting a new 4.3:1 back in would be the best option. These cars already have a good top end speed.
Old 04-04-2006, 11:19 AM   #6
suprra_girl
7M POWAH! ;)
well the jza70 R auto came with a 3.9 and jza70 R manual came with a 4.1
so maybe those will make up your mind
Pics of my build.
