Old 04-08-2006, 09:36 PM   #1
koenigturbo
koenigturbo is on a distinguished road
Red face Fluttering noise
I installed a "K' and "N" air filter the cone shape type it makes an awfull fluttering noise when I let off on the gas any one know how I can fix this or do I have to go back to the stock air filter,.. "yes I have a turbo car
koenigturbo is offline   Reply With Quote
Old 04-09-2006, 03:46 AM   #2
the_fallen
the_fallen is on a distinguished road
the fluttering is compressor surge from your turbo. as you shut the throttle body, the boosted air has no where to go, this is where the BOV vents it back into the intake. if you have a BOV and haven't done anything to it, then it's the bov just venting back through your intake. if you don't have one, then it's compressor surge, and thats not a good thing, as can damage your turbo.
the_fallen is offline   Reply With Quote
Old 04-09-2006, 05:10 PM   #3
Burn N' Up
Burn N' Up's Avatar
Not to be a terd but just for clarity, BOVs (Blow off valves) Vent to the atmosphere, and a Recirculation valve, vents to the intake. Should sound like, shaaaaa shaaa sh sh sh. Perfectly normal.
Old 05-31-2006, 11:05 PM   #4
msz31
msz31 is on a distinguished road
I had the same problem. I just re-oiled the K&N filter the other day and when I reinstalled it, I didn't hear the fluttering anymore. I think the seal around the base of the filter with the MAF is better now. I hand tightened the screw and it felt like it went on more snug this time.
msz31 is offline   Reply With Quote
Old 06-01-2006, 01:53 AM   #5
razerback121
razerback121 is on a distinguished road
Cant k and N filters damage your AFM, or MAF?? I heard thats what there best at doing.
razerback121 is offline   Reply With Quote
Old 06-01-2006, 02:07 AM   #6
efttup
efttup is on a distinguished road
try the blitz intake filter, its stainless steel and to clean it all you need to do is rinse through with water.... ive noticed that it sounds alot nicer compared to other intakes
efttup is offline   Reply With Quote
Old 06-02-2006, 07:06 PM   #7
MK3_300
MK3_300 is on a distinguished road
That sound is normal with the stock by-pass valve. As far as damaging the AFM, I don't see how as all the intake is doing is allowing more air to be sucked in and the AFM is only metering the amount of air that enters inorder to let the ECU know how much fuel to add.
MK3_300 is offline   Reply With Quote
Weird noise from rear trevor510 MKIII Supra 2 02-23-2008 08:46 PM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
exhaust noise toonen Non-Generation Specific Questions 2 05-19-2006 11:27 AM
Scratching noise in my '88 Black'88 MKIII Supra 2 03-24-2006 12:04 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
