Old 04-11-2006, 09:07 PM   #1
Tortilla
Tortilla is on a distinguished road
Default fuel leak?
Anyone have any experience with fuel leaks on supras? My '89 turbo had fuel dripping off the gas tank cover the other day after i filled the tank. After a couple days it didn't look like it was leaking anymore, think it's a hole in the tank towards the top? Or is there a valve that opens up if you overfill?
Thanks
Tortilla is offline   Reply With Quote
Old 04-12-2006, 05:29 PM   #2
j3pz
if it doenst happen again i wouldnt worry about it... keep an eye on it though
Old 04-13-2006, 12:42 AM   #3
Burn N' Up
Burn N' Up's Avatar
There is no overfill valve, if you fill it to the top of the tank fill hose it shouldn't leak, i do regularly (no topping off my ass). If it is leaking next time you fill it get a mirror on a stick and a flashlight and start looking for the leak, if it only does it when its full you might be lucky and just a have a crack in your tank fill hose instead of a crack in your tank. Good luck
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Hitting fuel cut redmaro MKIII Supra 9 11-25-2007 01:36 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
fuel leak kewlcoconut MKIII Supra 8 05-02-2006 11:29 AM
