-   -   Rust concern (http://www.toyota-supra.info/forums/mkiii-supra/4291-rust-concern.html)
G-string 04-16-2006 09:49 PM
Rust concern
Hey ive been taking apart my engine to replace the head gasket but now that the cylenders are exposed i worrie about rust, im not sure will it rust quick if exposed to air or is it not steel, im not sure.
The reason is that the head gasket set i ordered was the wrong one so i have to get another.
j3pz 04-17-2006 09:40 PM
if the cylinders are exposed they will build a layer of rust. either keep them oiled, or just wipe the rust off. you should be able to wipe it off because the walls should still be oily.
G-string 04-19-2006 09:34 AM
Thank, i was reading up and its aluminum (however its spelt) and well aluminum doesnt rust, but steel does.
