Old 04-17-2006, 02:15 PM   #1
twd420
twd420 is on a distinguished road
Default intake
ok i know this is gonna sound stupid but the only way i can put an intake on my supra is if my dad sees in print what exactly an intake does. so can anyone tell me what an intake actually does, and if it improves gas miles.
twd420 is offline   Reply With Quote
Old 04-17-2006, 02:24 PM   #2
Levi1717
Levi1717's Avatar
Levi1717 is on a distinguished road
Default More Air
An intake is just gunna put more air in the engine and make it get air to the engine easier. It probably could give you better gas mileage i'm not completely sure but it certainly isn't going to hurt your engine or car. So tell your dad its ok theres not gunna be any problem with it.
87 N/A with a new JDM 7mge.
Looking for a 7mgte
Levi1717 is offline   Reply With Quote
Old 04-17-2006, 04:37 PM   #3
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Er, what kind of "intake" did you have in mind? Intakes cover everything from the air inlet to the valve itself.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 04-17-2006, 06:53 PM   #4
Burn N' Up
Burn N' Up's Avatar
So lets go over everything. IF your trubo charged then the turbo inlet pipe is the first part of your intake. The big thing here is more volume due to increased diameter. Although this is behind the MAF sensor it again is allowing easier aspiration of the engine. IF you buy an FPIK kit from K&N or a 3" inlet kit from suprasport or someone you have a larger filter apature so you can fit a more free flowing filter.If your NA then your replacing infront of the MAF the same and behind it you'd be getting a short ram intake to increase efficency of flow and again volume.
If your turbocharged there is a whole seperate run of things that a better IC, larger IC pipping, different compressor wheel will do but it sounds like your not quite there yet.
So next on both vehicles is the intake manifold. Again its just more air moving more effeciently making the engine work less to get air. Yes there is a barly noticable increase in fuel efficency and usually a few horses from 1000rpm before redline up.
Old 04-17-2006, 09:43 PM   #5
j3pz
ya what he said
Old 04-18-2006, 01:05 AM   #6
twd420
thnx for the info, now i can ask for an intake for my birthday in 3 days. he needed a list and thats one of the things i wanted
Cleaning Intake & Injectors mrnickleye Supra FAQ 6 03-23-2007 04:26 AM
