Old 04-19-2006, 04:53 AM   #1
ram5757
ram5757 is on a distinguished road
Default Super Slow on D, L and 2 ok
I replaced the engine on my 87 supra (not turbo), only to find out that when I started on D the car was very slow, however if I start on L it works fine. I called around and was told I needed a tranny. So I changed the tranny only to find out that the problem was still there, I was then told to change the TPS, I did but the problem did not get solved, I was then told to change the ECT. My car has 89530-14220, so I got a replacement, but the problem still there.
Does any body have any idea as to where to go next. I got this car with half a block, the head was gone and all the wires and vacuum hoses had been taken off. Can I get a schematic of the vacuum and harness. I might be missing a connection on vacuum or the harness.
ram5757 is offline   Reply With Quote
Old 04-20-2006, 06:15 AM   #2
mrnickleye
mrnickleye's Avatar
You have a miserable problem. Good luck ! I've found the vacuum diagrams at the library, in the repair manuals. You can photo copy, or check out the book and take it home.
Super Monitor IHateHacks MKIII Supra 19 12-15-2013 10:59 PM
Hks super afr dieseltech24179 MKIII Supra 0 12-24-2008 05:56 PM
Slow Bubbles Into The Resevoir Tank Drag0na5h MKIII Supra 2 03-18-2008 05:37 PM
Slow Start jaysun MKIII Supra 5 09-18-2006 07:36 AM
