Old 04-19-2006, 06:25 AM   #1
Burn N' Up
Burn N' Up's Avatar
Default Retractor control box is the Integration Relay No.2
Hey guys, not really any questions here but i'm posting this in hopes that someday some supra owner will want to know exactly where the hell integration relay No.2 is like I was earlier tonight trying to track down a lighting issue. I figured it out and its the little blue Nippon Denso box in the driver's side of the dash. If you remove the undercover on the driver's side and imagine where the hood release would be if it were still in place, you'll see it staring right at you. A little blue box a little bigger than a pack of playing cards labeled "Retractor Control." The Retractor control box is the Integration Relay No.2.
I have an 89 Turbo 5 speed. Hope this helps someone.
Starter Relay? Passenger Kick panel? dannydavi MKIII Supra 8 09-24-2007 01:12 AM
AC and Heater Relay??? mxmusik_12 MKIV Supra 5 11-10-2006 03:29 AM
Where is this relay from? Isphius MKIII Supra 4 06-08-2006 12:44 PM
