Old 04-24-2006, 10:00 PM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Turbo-side Reinstallation Sequence
Anyone have any preferred order of reinstallation for the turbo side of the engine. I have the turbo itself back on and the oil lines all hooked up, and now must hook up all of the other stuff that had to be removed-esp. the hoses/tubes.
It's hard enough doing it once, given the very tight spaces, so I don't want to install anything only to find it interfers with another item.
I am very fortunate that I have another turbo car to look at-it's been a big help so far.
So, anyone who has done this have any last minute advice?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Passenger side window kewlcoconut MKIII Supra 1 03-29-2006 07:58 AM
