Old 04-24-2006, 06:20 AM   #1
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Post White Smoke
I usually drive my car daily so I rarely have this problem, but today I started it up after not driving it for about two days and it had a very hard time starting. But as soon as it did fire up nice, I looked out my passenger side window and saw a BIG cloud of white smoke fly by (a bit windy today). I find this problem occuring at random times, but usually the smoke isn't that bad and it's always white smoke. After I noticed this problem occuring I also noticed the difficulty in starting the car itself. Another thing that may help explain is that after the car is started and I add a little gas, it wants to choke and die. Most of the time I save it by reving the engine up a little higher than idle, but it wants to die sometimes even after that. Timing perhaps?
Drag0na5h is offline   Reply With Quote
Old 04-25-2006, 06:36 AM   #2
mrnickleye
mrnickleye's Avatar
You need to find out if ita coolant thats making the smoke. Coolant coating the 02 sensor will have a negative effect on fuel mixture. Too much coolant in a cylinder can cause hydo-lock, or not allow the fuel mix to fire.
There may other, unrelated problems causing the idle problem.
White smoke from exhaust manifold Rommy MKIII Supra 15 07-26-2009 06:32 PM
help! white smoke out tail pipe tone loc MKIII Supra 5 08-04-2006 10:29 PM
NEED HELP...Does white smoke = BHG? 87sleeper MKIII Supra 10 01-11-2006 12:38 AM
White Smoke at Startup Makavelli MKIII Supra 5 07-29-2005 02:45 PM
white smoke steve119md MKIII Supra 5 05-24-2005 08:57 PM
