Old 04-24-2006, 09:08 PM   #1
wesbam1
wesbam1 is on a distinguished road
Talking thirsty supra turbo
hi, just wondering what the mile per gallon figure is for these its the 89 turbo,I used it for work today about 90 mile round trip I filled the tank to half way and 90 miles later its about 2mm off the bottom white line Its my first 3 litre turbo is this about right? normal my exhaust manifold is leaking on the turbo side , my car also struggles to idle for about 50 secs could the leak affect the idle.
wesbam1 is offline   Reply With Quote
Old 04-24-2006, 10:01 PM   #2
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
I get ~21 mpg on average-mostly highway running ~75 MPH.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 04-24-2006, 11:01 PM   #3
ddmcse
ddmcse's Avatar
i think the tank holds 18 gallons
sounds like you used about 8-9 gallons
lets call it 8 gallons used thats like 11 mpg
you have any black or dark grey smoke when you punch it ? you must be running rich
my mileage dropped real bad a few years ago , i was down to about 13 mpg , but thats mostly boosting around not too much highway . I was running rich and i could see it on my air/fuel meter somehow during that summer i slipped into rich i changed plugs checked timing, kept going over and over the syptoms in the manual all that stuff.
what finally worked was replacing the vsv switches on the intake side once i got the egr vsv replaced i was back in the zone . i don't really care too much about the mpg number as much as seeing the a/f meter in right mix zone .
running rich is a waste of gas and horsepower and makes a black mess everywhere , running lean will kill the motor ..
do you know where the leak is ?
Benesesso just found a leak in his downpipe it's common and it's right near the turbo . it blows a ton of wicked hot air right into the back side of the engine and the firewall . another hot spot could be a crack in the manifold and you won't see that because it's hidden behind heat shields
i don't think the leak is causing such a drop in mpg , i'd say it's your mixture
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-25-2006, 06:00 AM   #4
wesbam1
hi,I got some one to check my exhaust smoke yesterday it doesnt smoke at all ,I took it for a 30 mile drive with someone following me and not a bit of smoke was seen, I do get a bit heavy footed in it though hard not to,80 -100 on motorway (uk mph)and have a habit of using too high a gear some times then planting the pedal<bad driving, I know. maybe not such a good idea in a car like this,awesom cars though,I wont be using for work too much thogh to keep the mileage down,could any one tell me if I can get my ecu chipped ad raise the boost slightly 2psi maybe and can the standard injectors handle it ?
